Discuss Extender for main shower on/off valve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all,
Looking to fit shower panels inside the main walk in shower. Shower arm for the shower head will be fine with the extra 10mm the panels add but the 3 controls for the water flow/temp and hand held shower head at the other end will need extensions to the brass outlets Inside. I have removed the surround and three knobs and offered up some cut offs off a mates spare panel with 10mm depth but the main on/off 1st round fitting before adding the square knob and Allen screwing it in with the surround back on will not reach the brass screw (41.5mm width screw) the other two I may get away with as they are small fittings (23mm) these round pre knobs screw in but would like to extend these as well so it looks like it did before. Have looked on the net and found one tap extender but was 19mm.
Any help or advice gratefully received, don’t really want the shower replacing!!
many thanks,
Chris
Reply to Extender for main shower on/off valve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
