Discuss Faulty NEST heat link? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am bench testing a Nest and Heat link. Wired it up as per instructions. Neutral and live, plus the live being linked to terminals 2 and 5. On a multimeter there is 240V between neutral and live, neutral and terminal 2 and neutral and terminal 5. When there is no demand for heat from the NEST and the hot water is switched off, the multimeter sees approximately 170V between neutral and terminal 3. Should this be zero?
Dave
Reply to Faulty NEST heat link? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few...
1K
Can anyone confirm that a 240v central heating wall thermostat can be replaced by the Nest E Heat Link? According to Google, the wiring needs to...
Deleted member 120897
Good Morning. I've been having an issue for a couple of days, that my nest thermostat is demanding heat, but the boiler does not activate...
2K
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
