Discuss feed and expansion tank but no vent?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi fellas,
At a house yesterday - had to drain down central heating system ( oil fired ) , to replace circ pump/ pump valves and 2 port valve. After refilling system had a serious problem getting heat into the downstairs rads - it was when trying to clear a poss air lock that I discovered there was no vent over the f and e tank. Normal vent from hot water cylinder over the 50 gallon tank but definitely no vent for heating system. Got things going by back filling system and letting air out of joint at hot water cylinder but first time I have seen this and wondered if anyone else has come across this……..
cheers
dave
ps definitely no automatic air vents elsewhere either
close coupled f and e by the sounds of it
you're thinking of combined feed and expansion where you just run 22 or 28 to the tank
close coupled is the standard set up
combined comes in two variants
one where you just connect directly to the bottom of the tank
The other where you tee into the feed and make a vent from there
Here you go
Edited my last post with more info
Pic here
yeah that's what I meant
yeah that's what i meant it's a Sunday not on top of the ball sorry Killy
ey don't apologise, with the thousand odd plumbing terms tis easy to get things mixed up
had a drink last night Irish? Haha
op when i come across them if there isn't a manual air vent on the coil if its easy i tee one in, i hate backfeeding
Saw one like this yesterday so is it ok to leave like this as it can still feed back into the tank
Thanks chaps - a new one on me. This sort of arrangement is thankfully not too common round these parts
cheers dave
cheers dave
if you come across one don't be tempted to change it.
usually changed to combined if the system has issues with pumping over or drawing air in
But less air issues once filled, most open vent systems i fit from new, i do it like this
A will never pump over and well said Killy never alter it, most of these did have a combined Feed and Vent pipe teed in just under the tank and then some smart bum decide they wanted a separate feed and expansion and the fun started.
Reply to feed and expansion tank but no vent?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
