Discuss Fernox TF1 compact valve leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got a Fernox TF1 compact fitted in the airing cupboard, and discovered this evening after the boiler had no pressure that it is leaking.
I've seen previous threads about this where it leaks from the cap however mine appears to be leaking from the bottom inlet valve, not on the filter itself but the red tapped valve , where it connects to the filter.
I'm pretty certain it is a leak here and it's not water running to it etc.
I understand there is a washer between the valve and the filter ? Should I try and just nip up the joint first, or is it likely to need a new washer? Just dubious of over tightening considering its a plastic thread.
It is only a small leak and obviously has been going on for a while unnoticed .
Just a quick saved image but it’s leaking at the point I’ve marked .
Reply to Fernox TF1 compact valve leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
