Discuss Ferroli DOMIcondens HE HIVE WIRING HELP. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
Araya h
Hello I am a diyer, I am looking at fitting a hive thermostat to my boiler but can't see a wired diagram of where the wires of the hive go on the boiler that's the only part I am stuck on so if anyone could help would be much appreciated.
Reply to Ferroli DOMIcondens HE HIVE WIRING HELP. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
