Discuss few rads not heating up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
koey2036
hi i've just installed a new heating system in a 3 storey house. its a indirect sealed system im not getting any heat to the rads at the end of the runs. could an air lock be causing these rads not to work? rads at the core of the run are hot. the flow pipe is piping hot between the boiler and cylinder but the return line is not that hot near the boiler? why is the system not circulating properly? don't think there is a problem with the pump. any ideas would be greatly appreciated
try turning the working ones off,if that fails drain trough returns until hot
try turning all rads off apart from the ones that are cold to try and push the heat to them
done that and they start to warm up but as soon as you turn the other rads back on they cool down again.
pipe sizes are correct 22mm and branches to 15mm to feed maximum 2 rads. pump is built in to boiler vaillant eco tech plus 630
suggest the system needs to be balanced as cold rads get hot when hot rads shut down:)regards turnpin
Reply to few rads not heating up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had...
Evening all. I have an open vented C/H system with a heat only boiler and 10 rads over 3 floors. I checked the system mid summer and all was ok...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
