Discuss Fill Valve for toilet tank fitting MG-8005 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DaveP
First of all hello.
can anyone help,what my problem is I had a new toilet put in and it started leaking and now I need a new fill valve, I no longer have contact with the person who installed it and have found it imposible to get the part it is a fill valve for toilet tank fitting (MG-8005)
think I could bulk buy 500 from china but only need 1 :)
Thank You
Dave
You don't need to replace like for like, you can get fill valves from any DIY shops. Any chance of a photo? I would recommend getting one with a brass thread
Thanks Scott
Here's a picture
Fluidmaster Side-Entry Brass Shank Side-Entry Fill Valve ½
There's others that are cheaper and will do the job, depends on budget
will go down to our local screwfix on Monday and get one.
Thank you it's great that people like yourself come on and help
Much appreciated
Dave
That's one of the problems you get when you install imported goods these usely come from the DIY sheds, nearly always a problem when they go wrong ,same when they are being fitted you also find that a lot of them are not WRAS approved, OK to import them, OK to sell them, But not OK to install them , its to do with the materials they make the internal components with
Whenever I see that turquoise colour on a flushvalve or inlet valve it goes in the bin. A Hong Kong special is almost always identifiable with that colour plastic on it.
Reply to Fill Valve for toilet tank fitting MG-8005 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
