Discuss Firebird Combi CH Not working in the Oil and Solid Fuel Forum area at PlumbersForums.net
Evening Gents. That time of year again the wife has demanded the CH Be turned on.
However, im having an issue with it - It simply isnt turning on.
The LED On the front panel illuminates to suggest the CH Has been turned on by the boiler, but nothing happens.
The HW works perfectly normal.
If i cycle the power (Reset) the boiler. Turn CH On via the Timer and the the burner starts for around 60 seconds and then turns off.
I have Bypassed the timer to rule that out as faulty (I replaced it with a HIVE Wireless unit earlier this year - CH Worked when i installed it)
Any suggestions on what i should be checking next?
Reply to Firebird Combi CH Not working in the Oil and Solid Fuel Forum area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Hi all, The day before yesterday early morning (23rd of Jan) the temperature was very low, about -7C, so before that, I set timer to start CH for...
Hi all, 12 year old boiler, regularly serviced working fine, then wife turned on hot water and it stopped working. Same then with CH. Left it for...
1K
I am looking to replace my existing Vaillant heat-only boiler with a new Vaillant ecotec plus 630 system boiler (30kW). I have a megaflo hot-water...
