Discuss Firebird condensing boiler in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi there
As you can see from the video below, our pump exploded. The question I have is, this pump is added to a firebird condensing boiler and when we found this mess the boiler and pump were stil operating but the pressure in the boiler was reading 0. Should the pressure switch have kicked in and shut the system down?
Thank you
  • 8115C63F-ADF6-4A47-BCBF-D2F86D0EC2D3.mp4
    1.8 MB
Reply to Firebird condensing boiler in the Water Underfloor Heating Advice area at PlumbersForums.net
I have a "Firebird Envirogreen Condensing Combi Oil Boiler 26kW" a part has went and I can't find it anywhere, I was at every plumbers merchant...
Our boiler is in the loft and I encountered a leak in a roof above our side extension store room which has transpired to be from the boiler...
Hi Can you help me determine if my new Navien lcb700 lsx is working as expected? I got the Navien oil boiler installed to replaced an old...
2K
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
