Discuss Firebird flue problem in the Central Heating Forum area at PlumbersForums.net
Thanks. I'll try and run the burner without baffles and the with the air slide well open.Wet sooty passages are horrible to deal with, really very little you can do. If its really bad take as many turbulators out as possible, put them in a container with hot water and bicarbonate soda and leave to soak and providing there's enough space for flue gases to pass bring the boiler on to dry it out. Once dry tackle it.
I've seen blocked condensate do this several times and its never an easy job. You also want to take burner out and maybe line the inside of boiler with old newspapers before trying to clean.
This is going to be dirty.
Good luck.
Thanks for taking the time.Your responses have to be cleared by admin because you're a new member, so I'm only just seeing it. I've haven't used dualx, although I've had a quick look online and the product looks OK. I've also run it through some of my fellow oil engineers with conflicting results. Some only do the old scraper and hoover method and some have said that the kamco cleaning products are better.
Are you a home owner or an engineer?
Reply to Firebird flue problem in the Central Heating Forum area at PlumbersForums.net
