Discuss Fitter refusing to connect gas hob as gas meter is too close to electric in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ridiculous to leave you without a hob for that, how is the hob a factor when a gas meter is too close to an electric meter. He ain't left you much choice really, just use a fire resistant board as said above.
I would make him another cup of tea in one of these:
My thoughts exactly - seems over zealous.
Think I'll box it in - seems like sensible safety precaution anyway.
That mug is ace... :)
Don't box the gas meter in, he'll come back and waffle on about compartment ventilation.
Use the fire resistant board to make a barrier between the 2 meters to stop them holding hands :17:
Extent the board up and out slightly between the meters, or box the electric meter in.
Cheers for the advice. Much appreciated. :)
Or box the elec meter in and once he's finished remove it :D
The title says it all really.
I had a new replacement gas hob and boiler fitted to an existing installation by a local Gas Safe engineer. However the hob failed (ignition circuitry malfunctioned) and whirlpool who manufactured it arranged to warranty replace the whole thing (there were loads of problems trying to get the part required).
The Whirlpool fitter came today, disconnected the old hob (during which time he switched off the mains so had access to the meter cupboard).
He then proceeded to remove the old hob and replace it with the new one.
He then said that the gas meter is too close to the electric meter so would not proceed with the connection to the gas as it is unsafe. He implied (I wasn't in, so my wife spoke with him) that it could not be connected until the gas and/or electric meter had been separated.
It is true that the gas meter is not 150mm away from the electric meter however this is an old house in which the meters were fitted many years ago - I believe before the intro of the regs that apply.
However I am now left without a hob(!).
My question is whether he is right to refuse to connect as the gas meter was sited before the regulations requiring a gap of 150mm came in and at the time complied with all relevant regs.
Many thanks - hoping for some guidance as I have a young family and could really do with cooking them some food(!)
Ben
Just wondering if the whirlpool fitter is also gas safe registered
The bloke is being a dick. It is not even AR, it would be NCS under the old regime. he obviously ha something better to do, or it was getting late.
I've heard of companies not fitting cookers, down to cooker points being blown 750mm.
Reply to Fitter refusing to connect gas hob as gas meter is too close to electric in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hi, I am a homeowner but caught between a rock & a hard place. I am trying to get a Vaillant ecoTEC 630 plus serviced but the gas safe engineer &...
Not sure what my options are here. Basically a friend of mine recommended his father in law to do our plumbing/gas work for our renovation. First...
2K
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
H
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
HRP123
H
