Discuss Fitting a Gas Fire on an external wall. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all.
My mother has a large lounge with central heating. Because the layout forces a sofa to block a rad she also uses a portable gas heater in the winter months. She now wants to replace this with a fitted unit.
The lounge has a faux surround on an external wall with no obstructions outside. It currently has an electric fire fitted, but there is a gas supply (currently capped) behind the surround pillar.
In the past she has suffered from the consequences of higher than normal humidity in this room, no doubt not helped by the portable gas unit. For this reason some sort of vented unit would be preferred.
Ideally, a rear vent which draws in air from within the lounge (requiring a secondary vent installed) would hopefully provide some circulation of air along with the heat. I don’t even know if such systems exist?.
Alternatively, a balanced flue system would be the other option.
In either case I appreciate a new compliant surround will be required. The current one is just MDF and formica.
I would like to purchase a unit for her, including surround, and have a gas fitter carry out the installation. As well as the double vented system mentioned above Some other specific questions I would like to ask include.
  1. Would a gas fitter be expected to create any vent holes, or would a builder also be involved.
  2. Would I be expected to let the fitter also fit the surround? A job I suspect I could do myself.
  3. Any recommendations for online retailers that would supply the appropriate gas fire and surround to guarantee there were no incompatibility issues when fitting.
Any additional advice would be greatly appreciated.
Mark
Look at Stovax , they do a good range of balanced flue fires/burners, not the cheapest but the flame picture is very good and the ventilation requirements are all through the flue. Any fitting advice and regulations would be better off from a GSR engineer, most engineers should be able to core drill a hole for the flue but each installation is specific in regards to hearth etc.
Thanks. for the response. I'll take a look at Stovax range.
Mark
Reply to Fitting a Gas Fire on an external wall. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am seeking some advice on how to seal up my sump pit. I currently get condensation on the walls and floor around the pit, and in the past there has been accumulation of mold on the walls, due to about 6" of standing water in the bottom of the pit. The air also smells bad and is somewhat...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a bathroom for a regular customer. She is of old age and is starting to get a little clumsy and her son has asked me to look at the old gas fire/back...
Full disclosure, I am an Electrician. One of my older clients has just had her fire capped off because it doesn't comply with today's regs and was told the regs are now retrospectively applied. This is the opposite of what I am used to. For example, if I do an electrical inspection and find a...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
We are considering buying a house which currently has a 20 year old Ideal Icos boiler, so we're factoring in replacing the boiler soon. Current boiler is on an external kitchen wall with the flue going straight out. However, it's positioned in between a door and the kitchen window, quite close...
