Discuss Fitting a new shower waste - gasket under flange or not? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I managed to get the broken shower waste body out of the trap. I'm about to fit a new waste, a much more robust brass item.
The trap has a big rubber gasket designed to sit flush against the underside of the shower tray.
Is it a good idea for me to fit a rubber gasket between the flange on the waste and the topside of the shower tray (I have a few), or will the rubber gasket that sits flush against the underside of the tray be sufficient to make a good watertight seal?
Underside eg between the trap and tray
And a small bead of clear on the top brass part eg between the tray and brass grill
Thanks Shaun. Yep, I know that gasket in the photo goes on the underside.
I was asking if it's a good idea to fit a second flat rubber gasket between the flange and tray rather than just using silicon between the tray and brass flange...?
No need to fit another just run a small bead of silicon
Reply to Fitting a new shower waste - gasket under flange or not? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
