Discuss Fitting Franke Fuji kitchen tap in the USA area at PlumbersForums.net
I am going to be fitting a Franke Fuji tap at my daughter’s. The tap comes with the hot and cold flexible tails, the hot has a standard nut and rubber washer on the end for connecting to a male compression fitting but the cold has a different end ( I think because it has a non return valve fitted), it is a male end without a nut or olive. My question is how do I connect up this male end, do I simply just put the 15mm supply pipe in to it and use my own nut and olive to make a compression fitting, if not what?
Hopefully pictures attached.
Thank you
Correct I know it’s weird it doesn’t come with a nut and olive for the price of the tap
Reply to Fitting Franke Fuji kitchen tap in the USA area at PlumbersForums.net
