Discuss Fitting wall hung gas fire after Bermuda removal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi cust wants new wall hung gas fire once his boiler is done, I've told him let me sort boiler then once back boiler and fire is gone I'll have a look.
money is definitely an issue now he is having the boiler done. Anyone fitted a fire after removing a back boiler? Any advice on best way to go about it to keep costs down?
You don't necessarily need a liner for a fire. Its easier and cheaper without one if the chimney is sound
That's true, I was just thinking whilst he's up there pulling the existing liner out it's easier to replace it than testing the flue and if it passes, leaving it without and opening himself up to potential future problems.
To the OP.
Tamz is right though, you don't "need" a box or liner for a gas fire !
To the OP.
To the OP.
Thanks.
To the OP.
Thanks.
If I get the existing liner removed and do a smoke test and it passes then I can assume it's ok to use the chimney as is?
And a visual obviously.
Yes.
As long as it is sound and you've checked in the room above and the loft for signs of smoke.
There should be no sign of smoke.
The smoke should flow freely and come out of the correct terminal and only one terminal.
You are allowed to warm the flue with your lamp for a few minutes (10 if necessary ) if the flue is not initially pulling well enough.
All windows and doors closed.
Any open flue'd appliances in same room that could effect the test should be lit.
If there are any fans in adjacent rooms the flue should be tested again ( if it passes), with the inter connecting door open and the fan running ( all other doors closed )
Have a good look up the flue to check for obstructions.
If all's well, fit a suitable terminal!
You can fit an open pot but it would be best in my opinion to fit one that prevents bum warming birds suffering the effects of CO2 and CO and falling down the chimney.
Yes.
You are allowed to warm the flue with you lamp for a few minutes (10 if necessary ) at the start of the test.
If there are any fans in adjacent rooms the flue should be tested with the inter connecting door open and the fan running ( all other doors closed )
That's what I was expecting. Customer has driven me mad, wanted to go and buy a fire on the weekend and have me fit it, had to slow him down and tell him no to buy anything until I have checked and tested the flue.
Thanks.
Pulling the liner out should be fun, spare trousers will be needed I'm sure.
Yep.
Gloves, dust mask and goggles are the order of the day !
Pick a nice day, take biscuits and a flask up there, have a sit and ponder over life whilst staring into the distance and enjoying the warm sun on your face !
Leave the phone in the van so no mithering individual pesters you on that grand day out.
If you discover what life's all about, will you let the rest of us know please ?
Yep.
If you discover what it's all about, will you let the rest of us know please ?
I suppose how long is a piece of string but how long would you allow for a job like this? I may have to bond around the fireplace to get a flat surface for the closure plate but fitting the fire is straight forward. I can imagine pulling the liner out will be a nightmare.
Would also have to run new gas pipe along the loft and and drop down.
I haven't seen it but the liner will normally come out easy.
Twisting and lifting.
Only you can guess the time for the pipe run, once that's there the fire's not a big job really.
Is there a hearth ?
To remove liner, test flue, fit pot, bench off, fit fire, connect gas, Test it, test spillage, clean up etc. I'd think a Day roughly.
If there's hearth and gas run .....? maybe another half a day to a day ?
Difficult to say without seeing it !
If they've not asked you for a price, don't offer one just crack on !
Is there a hearth ?
That's understandable as you haven't seen it, could be anything. There is no hearth, gas will be reasonably easy.
Ill price it for a day and a half.
Get a price for scaf wouldn't pull or install a liner off a cat myself
A chimney scaffold would cost between 400 - 800 depending where the chimney is.
If you are not confident on roofs, a roofer would probably do it for around 150.
If it was me id get a roofer. Ive got a set of foldable cats but used them once and felt a bit light headed and wobbly kneed.
Far cry from my younger days.
I'm not too bad on roofs. Apparently next flat along has a walk in loft with access to the roof which I will check out. If I don't fancy it I'll get hold of a roofer.
Reply to Fitting wall hung gas fire after Bermuda removal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
  • Article
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
