Discuss flexicom 30cx glowworm dripping from heat exchanger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi - my boiler starts to drip out of the bottom right corner (when facing it) when the heating and hot water are on. It drips a little when just one is on, but with both going, it drips quite quickly.
I opened it up and saw there is water dripping from the heat exchanger - bottom right.
Picture attached.
Please advise? Want to know what to tell my plumber before I get him out
Many thanks.
The only advice you need is don't open a boiler case if you are not a gas safe engineer
As above. The door forms a seal you shouldn't be taking it off. Get a gas safe engineer in
main thing to tell the gas technician is, my boiler is leaking somewhere, the rest is down to them
please don't mess with what you don't know about, leave it to your gas engineer
Reply to flexicom 30cx glowworm dripping from heat exchanger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
