Discuss Flow rate comparison s or y? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gassafe
Went to quote a boiler recently, 18 rad system, and was surprised to see a little 22mm mid pos valve in the airing cupboard. Customer says some rads struggle to heat, its a 28kw system at present.
I am going to quote a 30 cdi sys, would it be beneficial to change to a 28 3 port in airing or changing to a s plan in airing? Would either of these changes increase flow rates? Or am I wasting time?
Does anyone know the max btu through the different sized valves I am basically asking? A 30 cdi kicks out approx 100,000 btu!
ruff & ready- with a system designed with an 11deg C (old) drop 22mm will give you 13kW. With a 20deg C (new) drop 22mm will give you 23kW. So IMHO 28mm is required (22 & 40kw).
Can I suggest treating yourself to a copy of the Domestic Heating Design Guide a very good book full of all this sort of info. Have you done a whole house heatloss to size the new boiler a professional should not be guessing at the size should they?
Balancing the system may help or the system boiler pump may struggle with the amount of rads.. Maybe worth fitting an OV boiler with a bigger external pump.
According to honeywell
22mm 3 port is good for 13kw, 28mm for 23kw
22mm 2 port 23kw and 28mm 36kw
Am I right Roger that these valve have a resistance to flow of less than that of an equivalent length of pipe?
They always look like they restrict to me with that big ball in the pipeline but I am sure that is what I was told.
Have just ordered a domestic heating design guide! Bit of bedtime reading! I hope it has stuff like this in there or I'm blaming you :p
I'm not sure what the exact pressure loss characteristics are but the values I mentioned were those provided by honeywell on their training day.
But visually they have to be more of a resistance than a strait length of pipe. Even if the Csa is greater they will reduce flow as the laminar flow breaks down and reforms as it passes through the valves.
Where do you think I get all my info from ? It is now used as the base to teach the apprentices on C&G courses so if you don't like your bed time reading & keep falling asleep you most certainly can't blame me, you will just have to go back to school. LOL.
Reply to Flow rate comparison s or y? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
