Discuss Flow & Return firebird C26 combi oil boiler in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, can anyone tell me which pipes are flow and return please.
I removed old leaking 2008 C26 firebird oil boiler in June .
We have now completed damp proofing works & I need to extend these 4 pipes to go through the wall and into a new boiler room.
This area will then be stud wall and insulated so the pipes will be encased in the wall.
Couldnā€™t see anything on the boiler to indicate which 22mm pipe was flow/ return .
I know which was hot and cold so those have been labelled correctly.
Just need to know so I can label them up the other side ready for my boiler installer next year.
Thanks .
Flow is on the left.
You'll want to take those isolation valves off when extending them as there will be big restrictions having your entire system going through a small ball bearing inside them
Thanks much appreciated , yes those isolation valves are only temporary.
Reply to Flow & Return firebird C26 combi oil boiler in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
