Discuss flue 110mm from wall ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
looking for a boiler that is the flue is 110mm away from the back wall anyone any ideas
peace out
Centre?
yip sorry i should have explained more flue is running from boiler out side wall now vokera is 130mm from back wall to centre of flue and ideal is 150 from back wall to flue which would be the normal fit
but the existing boiler is a ferroili and its 105 from back wall so not much play to get new flue in existing bore
hope that makes more sense
Have you had a look at vaillant?
125 round about the same as the vokera at 130 just dont want to hang boiler next min theres not enough play in the core to connect if you get me 15mm sounds nothing but theres usually not much play in flues
Core another hole worcesters 180mm so there you go and fill the old one in and re brick it outside
Reply to flue 110mm from wall ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
