Discuss Flue too close to the window, gas safe not interested. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
samwilko
I went out to do a landlord safety check to day on an 8 year old property. There is a valiant ecotec 831 plus in the kitchen with only 220mm to the openable window.
There is a row of three of these houses all with the same flue too close to the kitchen window. All have passed every inspection up till now.
i phoned Vaillant just to double check i was t missing something here and for some reason this was allowed, you doubt yourself when everyone else has passed it and its been built so recently. They confirmed that it definitely needs to be 300mm away.
So i phoned gas safe just to double double check my self before causing any upset. I was shocked at the response I got.
I was convinced this was At Risk. window open, wind in right direction fault on boiler and hey presto carbon monoxide coming back into the kitchen.
According to gas safe though it is only non compliant. It would have been NCS when that existed but now its just non compliant and is not to be written on the CP12. He said I should just have a verbal conversation with the owner and that will suffice.
That is an absolute joke, how am I supposed to cover myself and make the tenant and landlord aware of the risk? By having a verbal conversation? I thought this was absolutely disgraceful, they are telling me to sign this off as safe according to the CP12.
quote; I was convinced this was At Risk. window open, wind in right direction fault on boiler and hey presto carbon monoxide coming back into the kitchen.
80mm not going to kill anyone though!
i think it should be a score system left to engineer.. 5=fekin dangerous-3= not right-1 its naff!
3 naffs and its sh1te
Wouldn't lose sleep over it. Lot worse out there. As long as co detector in house and all working ok just note that you mentioned it. Not saying it's right but demo won't cause any danger so can't be at risk.
I thought ar as well. There's potential co could enter the property, how Is that NTcs?
Sure it says in the regs its only AR "if following an assesment POC are found to be entering the property"... See quite a few that are under 300mm think you just need to use your own judgment
Because it's diluted with outside air. Let's face it there's a potential with 300mm all depends on the wind direction.
its not fitted right but as wattsie says theres a potential even potential for CO to enter at 300mm given the right conditions. i wouldnt be losing sleep for 80mm just right it down on the sheet then your covered.
Reply to Flue too close to the window, gas safe not interested. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
