Discuss Franke Minerva 3 in 1 hot water tap plumbing advice in the USA area at PlumbersForums.net
Our newly installed franke hot water tap keeps running out of hot water when there is plenty in our heating system. Is this because the hot water supply is also coming from the small Franke boiler? I had assumed it would be just the boiling water part of the tap that this tank feed and the hot and cold water would still come from the usual old supply. Do you have a choice when plumbing in the tap where the hot water supply is from ? if so is it simply to swap so we don't keep running out of hot water when we have loads available in our old hot water tank upstairs. thanks
When fitting the franke Minerva 3 in 1 hot tap do the normal hot and cold supplies go straight to the tap and not through the M Box.
Reply to Franke Minerva 3 in 1 hot water tap plumbing advice in the USA area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app 2hrs in morning 2 hrs in evening Any help be much appreciated
Hi, I'm looking for a water pump to pump water from a storage tank at a constant 3 bar pressure. It's at a campsite I run that's at the bottom of a long, steep hill. We struggle with very high and often fluctuating (around 7 bar) water pressure, which wreaks havoc with our water heaters. I've...
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
