Discuss Franke Monoblock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Smithyneal
Having loosened the allen screw the tap seems to be fused onto the valve. Any ideas on how I can get it off to replace the valve?
Normally need to give it a wiggle, especially if its fairly old.
When you put it back together make sure you grease the washers with either a silicon grease or Vaseline.
Reply to Franke Monoblock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
