M
moony
from bath store - had a night mare fitting it.
basically its a bath on legs that sits inside a surround - the surround, is bolted to floor with clamps... easy eh... the hot and cold is concealed in the surround easy so far - so is the waste.... ok can sort that out....
here comes the stupid bit.... the bath itself is lowered into the the surround then the surround is screwed up to the bath.... how the flippinhell do you connect the waste ? there is no room for a flexi waste (which i dont like to use anyway) the bath taps yeah ok use long flexis and when bath lowered take the chance on the flexis sitting without kinking as lowered but the waste? you cant attach trap to waste and lower and screw in from above to attach waste as its a pop up waste controlled by overflow. hope ive explained this well - and anyones thoughts on how to do this easier next time - (we have managed it but it wasa bodge really drilled through side of surround as it was close to wall (but these baths normally go in middle of the room)!
