Discuss Freezing pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jacko
hi not posted for a while, i have a lockshield to change tomorrow and have to freeze due to size of system only using disposable stuff any help or advice much appreciated how much distance do you need before the valve to freeze it
thankyou in advance :)
Never had much luck with freezing/its expensive. I often bung the header tank, create a vacuum and use some towels.
Hire a decent freezing machine. The disposable stuff is not great to be honest.
Advice;
Plenty of rags
A few buckets
More than 1 can of freezing stuff.
Make sure the water you are trying to freeze is cold and unlikely to get hot.
how long do you get once frozen only ever seen it done by otheres not done my self
I have done loads. Either hire an electric one like the rothenberger rofrost turbo etc or a polar freeze kit like Commercial Pipe Freezing System | Specialist Plumbing | NoLinkingToThis
Shut boilers and pumps down and wait to cool to room temp. Electric machine keeps going forever and cans last a fair while ie 20 mins plus.
Dont freeze under where you are working as any water dripping will melt the ice plug. Have a cap and new valve etc ready! Relax and have a cuppa while you wait for it to freeze :shades_smile:
I bought a pipe freezer years ago, on a job like this its the absolute dogs !!!
As said, hire one, but pass the invoice on to the custard, and explain how much he is saving.
Reply to Freezing pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a leak on the live side of one of my rads, in the GF loo. Its a condensing combi system, the house is only 5 years old, so fairly new...
1K
Hi have surplus water feed and return pipes in my home. I can't isolate them so will need to freeze. House built 1970's. They're as far as can...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
