Currently reading:
Frozen condensate pipe
Discuss Frozen condensate pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Backboiler
Been out to loads of these last week but unsure how much to invoice agent for. What are you guys charging for this?
Standard charges, charged a bit more Saturday as it was my day off; had to call my mucka in and go and replace loads of outside taps!
Depends locally and a good customer 20-40
Far away eg 20+ miles 80
Bad customer 80
And yes charge to reconnect and adjust if not to spec
One thing that has annoyed me is, I have advised at least 10 customers how to sort it themselves. Some are friends, some I don’t know.
All must be sorted, as I’ve not had one ring, or text to say it ok now. Or just a thanks!
Dont go back for free unless you charged enough first time to cover both visits and materials
Is there a Technical bulletin covering air breaks, condensate regs etc?
I think I need to refresh my memmory @ShaunCorbs
I will not charge to couple back together but will charge to upgrade. I have also advised customers over the phone (the ones I couldn’t get to) I bet I get a call back when they need something else doing.
Yes there is also covers install to rain water pipes
Will link it when I'm back at my comp
worky or no worky :D
  • INDUSTRY GUIDANCE ON CONDENSATE.pdf
Anybody fitted a Worcester Condensure, that it was quite a good idea in principle.
Yea very good that hasn't frozen yet
Ive been fitting trace heat to fridge plant for nearly 30 years operating at -25 and have never had a problem with drain lines freezing. The same with all of my installs
Reply to Frozen condensate pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
