Discuss FS: DALLMER Marmox Showerlay Gulley Drain Trap with 22mm Whale Pumped for TILES in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andrew2000
Ebay UK 130734493933
This is retailed by a specialist wetroom supplier, £114, boxed new with tube of sealant for £39.
Basically it converts the Marmox Showerlay system to work with Whale Gulper 22mm.
Can not see it go to waste as it may save someone a chunk of money - or give a chunk of profit.
Reply to FS: DALLMER Marmox Showerlay Gulley Drain Trap with 22mm Whale Pumped for TILES in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Sonya K
