Discuss Fuel pump voltage at 80volts in the Oil and Solid Fuel Forum area at PlumbersForums.net
Dave hall
Hi, just fitted a new fuel pump and control unit to my ecotherm boiler but I still can’t get any fuel to the top of the pump, nothing coming out of the bleed screw but definitely fuel in the bottom of the pump. I checked the voltage to the pump and it’s only 80volts but there is 240volts going into the control unit.
Any ideas
Reply to Fuel pump voltage at 80volts in the Oil and Solid Fuel Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the...
