Discuss fuses keep blowing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
louisqaz
hi we have an apollo 30/50 boiler which keeps blowing the 3 amp fuse it seems to happen when the room thermostat is turned i have replaced the thermostat but the problem has not gone away any ideas thanks
If working ok on hot water mode,not likely to be boiler,is pump or anything leaking on c/h motorised valve maybe,inspect wiring connections
imho
would the suppressor have anything to do with it as this has burnt out
Wots a suppressor? disconnect the pump and safely insulte the wire connections and select the heating. If it fires you prob is the pump, if not I would think it your valve
Reply to fuses keep blowing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
