Discuss Gaining extra hot water pressure. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dan Masey
Hi all, im new to this forum. (normally use the tiling forum). Been plumbing for 8 years now and im still finding useful topics on here. Iv had a few issues lately when installing bathrooms. More and more people are having fancy mono block taps that work terrible with the gravity fed hot water. Sometimes they are happy to pay for a pump but other times not. Is there a better, quicker, cheaper option? Will changing a 25 Gallon tank to a 50 gallon tank help? Most pumps require a 50 gallon tank anyway. Or maybe change the 22mm feed to a 28mm feed to the cylinder. Would that help?
any help will be great,
Dan
Raise the CWSC (and header) if you can and make sure that they have specified the right taps.
raising the tank by 1m will give me 0.1 bar of pressure extra. Hardly worth the effort and makes the tank top heavy. Bit risky. will a 28mm feed help?
.1 of a bar may well represent a 10% increase and only top heavy if not done right. Like on matches ;)
Putting a larger pipe in will not increase the pressure by very much although it will reduce the resistance slightly. A larger pipe is normally used to improve flow rates.
You either need to pump it or raise the cold water storage cistern.
The best solution is to specify taps that are suitable for the customers water system.
Or if they insist, warn them on paper that the HW may be poor.
Surely the hot and cold water pressure to the bathroom will be the same on a gravity system!
You or your customer need to ensure the specified fittings are suitable for a low pressure system.
Pumps, or a pumped shower is generally the cheapest option.
Reply to Gaining extra hot water pressure. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
J
Hi Can somebody tell me if a standard heat source pump installation uses a pressurized hot water tank? Or will the pressure for the hot water be...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
