I wouldn’t even worry about it. Looks like the top is nearly touching and due to the angle of flue, the bottom has opened up a bit.
I’m not saying I’d install it like this but if we use a bit of common sense, it’s the air intake. It’s not an air tight seal to begin with, so a 5mm gap, makes very little difference.
It’s not under positive pressure, so any leak in the inner tube won’t get forced out of the air tube but rather sucked in to the boiler and reburnt.
If I found it, rather than break cement, dismantle/reinstall flue, I’d test and likely wrap it with silver tape, refit the clamp and screw the clamp.
I’d also be quite happy to stand up in court and explain my decision process.
Sometimes we as engineers need to use our common sense and on site judgement.
Now if I found something like this......it’s a different story....
