Discuss gas cooker rigid piping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
CXR100
is a gas hob with a bayonet hose on an existing installation ok on a landlord safety cert? I am running a new supply from the meter to the boiler, am I obliged to change this? wouldnt be much extra work. also got a flue to clip in the attic, runs up direct in the middle of the roof space, so cant fix clips anywhere, whats the best way to do this?
depends if the mi allows it, some do? my beumatic range does!
3x2 timber joist to rafter support!
check MI and condition of the hose. If its showing signs of stress, in danger of damage or touching the cooker underneath then best to change it.
As for the flue, use timber as Red has suggested, build a frame alongside the flue, clip every extenstion and change of direction and you will be fine. Also if manufacturer allows self tap each joint.
Reply to gas cooker rigid piping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, my mother had an electric cooker installed yesterday. The guy who fitted it said it shouldn't be close to the gas pipe but it is. The red...
1K
Hi, I am a homeowner but caught between a rock & a hard place. I am trying to get a Vaillant ecoTEC 630 plus serviced but the gas safe engineer &...
1K
So we are looking at a new vaillant ecofit pure 418 regular boiler but have a question about the gas pipe size requirements.. At the gas meter...
4K
Just to be really clear I will not be doing any of the work mentioned below. This will all be carried out by Gas Safe Engineers. We're in the...
3K
Hi. I have been on the phone to the Gas Safe Register, who have pointed me a bit in the right direction looking for certain information. I am in a...
3K
