Discuss gas electric appliances containing asbestos in the Plumbing Jobs | The Job-board area at PlumbersForums.net
good call its a must have..i'd advise everyone on here to follow suit..............
just looked in the list the now and opps is a good one a have potterton netheat coming out tomorrow
The asbestos on a netaheat is the rope gasket on the flue hood which you have to take off to get the flue off.
yeah the netaheat seal will prob fall apart when you touch it. then you should get competent person in. known on most sites as the tat man.
I always spray loads of water over the rope seal before removing the flue hood and then again the gasket at the rear around the flue which I was also told was asbestos. The more water, the less chance of any nasty dust particles.
Reply to gas electric appliances containing asbestos in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, My customer needs a new water heater/boiler - preferably electric. (Getting the gas pipe through to the desired location is a bit of a...
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
  • Locked
I have my initial gas safe inspection coming up after successfully completing my ACS a few weeks ago - and, it's fair to say i'm slightly nervous...
4K
M
  • Locked
There's been a few queries as to whether appliances contain asbestos recently. This is the tech bulletin that Corgi sent out a few years back...
1K
Mike Jackson
M
H
  • Locked
Hi all, Been wondering recently if there is a list or some kind data sheet containing general fga tolerances for different appliances? I know...
8K
HeatStar
H
