Discuss gas hob clearance in the Plumbing Jobs | The Job-board area at PlumbersForums.net
buckley plumb
can anyone explain the clearances on the gas hob pic in viper and b pec book shows 300 from a wall etc and 760 to hood or cupboard above but what does the 50mm mean on the pic either side of hob I have seen hobs closer to wall than 300mm would post pic but cant upload
The 50mm either side is the minimum clearance from work tops/units.
next to hob? if 300mm from wall must be same to unit
Maybe the 300mm takes into account and assumes the wall will have a combustable surface?
The 300mm to the side is recommended, but can be reduced if the material is non combustible and is for using the appliance and for clearances for pot handles etc
The 50mm either side is to do with the height of the wall units from the Worktop
If the units are more than 450mm above the Worktop they can be vertically in line with the edges of the hob
If the wall units are lower than 450mm from the Worktop the edge of the units must be set back 50mm (on either side) from the vertical line,
So if you have a 500mm wide hob and the units are high the units will be 500mm apart, if the units are lower than 450mm they will need to be 50+500+50 apart, the reasoning being if they are lower there is a higher risk of them getting burnt
Does that make sense?????????
Makes sense to me. I've read it over and over trying to figure why you're not getting it but it does make sense.
cheers why could they not put that in the book it makes sense now
That’s not gonna work! How would you make 50mm clearance around a hob!? The hob simply will go through the hole! There’s a hob and there’s a free-standing cooker
Clearance around a cooking appliance and within the kitchen furniture shall be in accordance with the appliance manufacturer’s instructions…
In the absence of specific guidance in the manufacturer’s instructions, BS 6172 gives general guidance onclearance zones, which should be followed.
Reply to gas hob clearance in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just to be really clear I will not be doing any of the work mentioned below. This will all be carried out by Gas Safe Engineers. We're in the...
3K
Hi guys, I'll try to describe my issue as best I can but I've attached a video and linked to some images below that might do a better job of...
2K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
  • Locked
A couple of years ago, my mother moved house and paid an RGI to move her existing ca. 1981 Solaire New World cooker into her new house (there was...
R
  • Locked
Hi, I was asked to install a gas hob today, the manufacturers inst recommend 300mm to any combustable material at side of hob, the clearance I...
5K
