- Messages
- 7,712
Discuss gas meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A free manometer and hose?
ECV falling to on..
ECV falling to on..
If its off,its probably passing..Unless its off of course.
Why on earth would anyone paint the gas pipe?!! (oops, no pun intended!!)
The on /off tape appears to be upside down.
If the handle can travel past the horizontal to point downwards then its clearly falling to on.
If the handle is in its horizontal stop position and needs to point up to be on then the on off tape is wrong and further,if thats the case,the handle has passed its horizontal position before stopping and so the stop pin is likely bent thus allowing it to overtravel past the horizontal leading to a possible passing when off situation. Painted pipes ? horrible..looks like cheapo new build. Hides all that self clean flux gunk which should have been wiped off.
ECV falling to on..
Would you say this is NCS or AR?
Reply to gas meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
