Discuss Gas regulator keeps tripping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Matt_S
Hi all,
Last winter our gas supply cut off, so I called our gas supplier. A chap came round and showed me a green button next to the meter outside which resets the regulator. After that I had to do it a few more times. The rest of the year since has been fine, but now for the last couple of weeks I'm again having to reset it again, although daily, sometimes twice a day.
What causes this? High pressure? High demand?
Who should I call? Could it be a problem with my boiler or a faulty regulator?
Sorry, lots of questions. Any advice really appreciated.
Matt
We've been experiencing the same problem and the only thing we can put it down to is the cold weather!
Thanks for your reply. The cold weather must be a factor, but none of my neighbours that I know of are having the same problem. The houses are only 4 years old so everyone has the same system in their houses.
Matt
Get the gas company back out.
Reply to Gas regulator keeps tripping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Have had a fault on our Ideal Icos HE15 boiler for a couple of weeks, keeps failing to light and shows LF (or FL) error. Boiler engineer...
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
1K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
1K
H
HRP123
H
