Discuss Gas Restrictor Elbow help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Needless to say I will not be touching anything gas related myself in future!
Pulling gas fires around may damage the flue arrangements, which is dangerous for your and your family. Carbon monoxide has no smell and is a killer. Messing with gas restrictors and seals is also dangerous. Even its not leaking now if the seal wasn't remade correctly it could start doing so in the future.
Get a Gas Safe engineer to service the fire and check all is well. Tell them what you did and why so they can make sure you haven't damaged anything. If you want to clean behind the fire and there is no other way (like a long radiator brush) get the GSR to help with disconnecting and reconnecting.
Thanks for the advice. I'll call my plumber tomorrow and ask him to take a look at it for me.
Thanks again.
Reply to Gas Restrictor Elbow help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
