Discuss Gas Safe website notification boiler warranty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dom Perkins
Registering a boiler I've just fitted on the Gas safe website and as I nearly always usually fit Worcesters have never seen the 'warranty registration' option, now that im registering a Baxi Duo-tec...
The home owner is elderly so i suggested I try and register their warranty for them over the phone, however over the phone Baxi wants to speak to the home owner.
Can I use this option on the gas safe website to register the warranty then?.. when I type in the serial number, it doesn't ask for my customers name or address, which I thought odd.. so Gas safe registers the warranty with Baxi for me?.. that part of hundreds of pounds I handed over earlier this year?
Anyone know how this works,
cheers
Get the baxi work mate app
Does the warrenty and gas safe in one
I rarely fit them tbh Shaun, so the App wouldn't see much use and i'd probably have to register a load stuff with them to get setup.. Also tried to do it online, but there isn't a security code at the end of the Boiler serial number, that the website register seems to demand..
The extra digits are on the label sheet that is in the MI pack.
The online system does ask for clients address
Join baxi works piece a Sod to use they will registerer the boilers warranty and with gas safe free as above you need extra digitits off the boiler serial number sticker , cheers kop
Reply to Gas Safe website notification boiler warranty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
