Discuss Gas Test Gauges in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
Wonkee17
Hi all,
I am currently doing so research about Gas Testing Equipment, in particular, Gas Test Gauges.
During my research I have come across manometers/ u-gauges, which seem very similar to gas test gauges.
Would anyone be able to explain what the difference is between a u-gauge and gas test gauge? As far as I can see u-gauges are use to test drains and pipes, whilst gas test gauges check the pressure of gas pipes and appliances.
Also, how would you use a gas test gauge?
Thank you in anticipation of your help.
They have different scales but basically rely on the fluid acting against a gas. Basically F=mgh? Or u could use f=ma both give identical results ?
Reply to Gas Test Gauges in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
