Discuss Gas valve for hob behind cupboard. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It is actually a service valve. If I’m honest.It’s not an end user valve, they would shut off the ECV in an emergency.
Fine to use a compression valve.
I was told this on a gas safe inspection
You cannot use a compression valve on gas that isn’t accessible mate. The oven is screwed in which means not accessible.It’s not an end user valve, they would shut off the ECV in an emergency.
My training centre.Says who ?
Only time you cant use compression is under a floor
My training centre.
By removal of 4 screws it becomes accessibleYou cannot use a compression valve on gas that isn’t accessible mate. The oven is screwed in which means not accessible.
Accessible is when you do not need a screwdriver to gain access.By removal of 4 screws it becomes accessible
A gas meter and ECV are not accessible without a cupboard key
Maybe. But it is what I was taught.My training centre.
Reply to Gas valve for hob behind cupboard. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
