Discuss Glow-worm 24kw Betacom 4 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good evening
What would be the gas rate on max Ch and Max Hw
Been set question but can't find the info
More intrigued why someone non Gas Safe needs to know
Perhaps he's training and been asked by his employer to find the values to show he understands how to find the info in the manual.
That’s fine but he also has other threads asking re unvented set ups etc just want to make sure we aren’t encouraging a fiddler
Yeah just looked through his other posts, could be training but could be fishing also.
All the info you are seeking for that model is in the Glowworm MI’s. Qnw is stated in steps across the full modulated range. The MI’s should be in the pack that was handed over when the boiler was commissioned.
Please don’t be tempted to use the information to undertake any procedures that require a Gas Safe Registered Person.
Glowworm (and others) generally state that the gas rate is factory set and no attempt should be made to adjust it (at the boiler) by anyone ( Gas Safe Registered or not). Adjustments, if required, to the installation pipework from the ECV to the boiler may only be made by Gas Safe Registered persons.
Setting the Glowworm on to maximum and measuring at the gas meter is fine.
All the info you are seeking for that model is in the Glowworm MI’s. Qn is stated in steps across the full modulated range. The MI’s should be in the pack that was handed over when tue boiler was commissioned
Good edit :D
Reply to Glow-worm 24kw Betacom 4 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Does anyone know where I can find the decibel rating for the British Gas 330+ boiler? I'm looking to get it replaced and wanted to compare it...
A
Good morning. We have a 10 year old Ultracom which now very frequently thinks there's a demand for hot water, even though there isn't, so the...
Andy Don
A
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler...
Hi all We have a Glow Worm combi Ultracom 38cxi boiler fitted in our house, which has been running really well for the past 10 years. Recently we...
