Discuss Glow Worm 30cxi - Main PCB blowing, any advice? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SlammerUK
Good Morning Everyone,
I have a Glow Worm 30cxi Condensing Combi Boiler.
Last week, the main pcb died. I got the board replaced (4000124180). Boiler came back on, happy days.
I did notice that the water was nowhere near as hot as it should be and been advised the Plate to Plate Heat Exchanger probably needs cleaning/replacing and would fix this issue, so thought I'd get that done if the boiler was still functioning in a weeks time.
Then this morning, the board died again. So its lasted approx 72 hours before blowing again :veryangry2:
If it helps the diagnosis, the central heating has been turned off ! Its purely been used for hot water so has had very little use.
Obviously getting a new board and fitting it, is going to have the same effect as there is an underlying issue. Is there a common fault that could be causing this? Or anything I should be checking?
Im surprised/disappointed that any part which has developed a fault can take out the main board like this? Surely if its overheating for example due to the whole system + plates needing flushing, it should just shut down?!
Thanks for taking the time to read and hopefully help me solve this :)
Thanks, Mark
Reply to Glow Worm 30cxi - Main PCB blowing, any advice? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
A
Good morning. We have a 10 year old Ultracom which now very frequently thinks there's a demand for hot water, even though there isn't, so the...
Andy Don
A
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler...
Hi Have a Glow worm Flexicom 30cx-Installed 2010 and regaularly serviced. Last service October 21. Works fine, with no issues. However it has...
    • Funny
    • Optimistic
Hi, I've got a ferroli 901 boiler, I initially thought the pcb was at fault so bought a new one and I'm having the same problem ( has been...
