Discuss Glow Worm 30sxi boiler hot water says no... in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a Glow Worm Ultracom 30sxi boiler that provides central heating and also heats a hot water tank. There are no error codes shown on the boiler but recently the hot water has stopped working. If I try and change the temperature under the tap symbol, it just displays 'no'.
The boiler is connected to a Honeywell controller with set times for hot water, central heating etc. It seems like the boiler has lost connection with the control unit - if I put the hot water onto continuous it has no effect. Presumably this is to do with the 'No' message? Has anyone else come across this? Thanks for any help in advance.
As a temporary measure you can use the immersion if you have one, or latch the hot water valve in manual position and use the heating to heat it up. Just be careful of hot water temperatures doing it this way, as it’ll have no temp cut off other than the room thermostat.
Reply to Glow Worm 30sxi boiler hot water says no... in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all We have a Glow Worm combi Ultracom 38cxi boiler fitted in our house, which has been running really well for the past 10 years. Recently we...
When I put the central heating on the hot water gets drawn through the pump but is then being diverted straight back to the boiler instead of the...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
A
Good morning. We have a 10 year old Ultracom which now very frequently thinks there's a demand for hot water, even though there isn't, so the...
Andy Don
A
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
