Discuss Glow worm betcom 4. Making noises in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi guys, replaced a combi swap a few months ago and customer has contacted me, saying sometimes when they open kitchen cold tap the boiler makes a noise but doesn't fire up?
I connected hot and cold correct way if your asking lol.
The mains pressure is very high could this be causing problems when kitchen cold tap is closed after it's been turned on? Back pressure?
I installed boiler to the mi.
best get the manufacture out as pressure shouldnt effect it
I went to see it today. When you open a cold tap the pressure on boiler slighter rises with a noise?.
When tap is closed the pressure goes back to normal.
It's like a surge of pressure that is doing it? What if I put a shock arrestor on the cold pipe going into the boiler?
Reply to Glow worm betcom 4. Making noises in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
