Discuss Glow Worm Flexicom 30cx in the USA area at PlumbersForums.net
Hi all. Got the above combi which had an F25 (circulation) fault. Had new expansion vessell (was bad) then at advice of Glowworm a new diverter valve as hot water was OK but fault on heat. All has been perfect for a few weeks then back to F25. As before cutting power cures it. Always from cold. This time both Hw and heat. The only catalyst this time is I turned down a radiator valve. Had a big bill last time so trying to pre-empt this time. Pump is very strong (screwdriver test).Thank you..
Reply to Glow Worm Flexicom 30cx in the USA area at PlumbersForums.net
PSxxxxxx
