Discuss Glow worm flexicom 30cx in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Check flow switch, diverter valve.Hi all,
Just got a call to look at one of these boilers, heating ok no hot water any common problems with these boilers?
Check if heat passes down flow pipe to test if the diverter is stuck. It's pretty rare that they stick, pretty common that they leak through the spindle.
First thing I would actually check is that the plastic filter isn't blocked and preventing flow through plate, it has in internal bypass that it'll run through if the filter is blocked
Reply to Glow worm flexicom 30cx in the Plumbing Jobs | The Job-board area at PlumbersForums.net
