Discuss Glow-worm hideaway boiler issues in the Central Heating Forum area at PlumbersForums.net
C
Colin ash
I have a old glowworn hideaway boiler which has been working perfectly until a few days ago, had a engineer come out and change the thermocouple and it now ignites and stays lit.. that is until the central heating is turned on, stays on for around 10 mins and then completely cuts off. Reset everything as the manual says. Still does the same, however it stays on with no issues when just the hot water is on, pilot light stays lit. Anyone any ideas?
I have EXACTLY, the same issue with a potterton boiler.
Works fine as hot water is heating as soon as my rads heating kicks in it goes flat the red light comes on, no rads working, I reset via button and everthing kicks back in and wirks as it should be until next time heat repeat reset.
Driving me crazy.
Glow Worm:
Yes, it is a common problem - usually lack of a good service - and an easy fix for someone who is experienced with those boilers.
You need someone gas safe registered.
Potterton:
Your issue is different but should also be an easy fix but maybe with a part replacement.
But clearly beyond the knowledge of a BG engineer then
I have a home service sub the boiler gets serviced every year and has only just been serviced, the issues have been bought up with them several times but after each visit the issue is still there.
Perhaps if you can let me know the well known secret I can pass it onto the BG engineer as BG seem to have not got the memo 👌🤣🤣
Could be a weak pump causing a genuine overheat lockout due to lack of circulation.
Reply to Glow-worm hideaway boiler issues in the Central Heating Forum area at PlumbersForums.net
Went to a customer today their glow worm Ultracom 24 HE goes to fire up then cuts out turning the heating pump off, then does the same again...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
I have an old Modena 80 E combi boiler that is randomly short cycling on windy days. The burner goes out and re-ignites within a few seconds and...
I have a 40 year old floor standing Glow Worm 45-60 boiler (open vent )which is in a cupboard in the centre of the house. Its an old workhouse...
  • Locked
I have a 40 year old Glowworm Hideaway 100. I have lived in this house for 8 years and it has been faultless, until recently. The pilot light...
5K
