Discuss Glow-worm Hideaway FF: on, off, on, off, on...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
State of Flux
Scenario:
- pumped CH in 22mm, Gravity HW in 28mm
- stat and two channel programmer working fine
- pump spinning (whole house gets heat within a few minutes)
All as you would expect from a 2005 installation and the house gets heat and HW.
Question:
- how frequently should the boiler be cycling on and off? (I'm no expert on this boiler)
When the rads are cold and the cylinder needs reheating it only runs for about 10 minutes then shuts down. 5 minutes later, up it comes again. Everything shouts OVERHEAT STAT in boiler but it does it so quickly.
I'm minded to change the (10 year old) pump as it's noisy but don't expect this to stop the cycling as the issue is there in HW only. Might it simply be a faulty overheat stat that needs replacing?
Appreciate your insights...........
you will get limited response but,
what is the temperature of flow and return?
what setting is the thermostat on?
Simon, thanks. I've tried low, med and high on the stat with no change. I'll measure temps when next there to see if it is simply failing to lose enough heat but I'd be surprised given that the rads and water get piping hot. Wondering whether the overheat stat is simply too sensitive in its old age.
It's not the overheat stat. Sounds like normal operation for a boiler with gravity hot water.
Cheers for the inputs. Owner looking to extend property and replace at some point - will advise to live with its foibles and save up for something better
Reply to Glow-worm Hideaway FF: on, off, on, off, on...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi everyone, I'm looking for some advice please. My system has 5 Drayton Wiser TRVs. There are 8 rads over 3 storeys and a 170l unvented...
2K
Hello ! I have recently moved into a new house – or rather a 1960s built house. The central heating system looks to be around 10-12 years old...
4K
This is a long shot-( this post was originally sent to StevethePlumber but I havent heard back from him as yet) I have a glow worm ultimate ff...
5K
Hi Everyone I've got a quite old Glow Worm Ultimate 80FF. It recently had an issue with the control stat (lots of green corrosion on it which was...
4K
