Discuss Glow Worm spacesaver pilot assembly in the Gas Engineers Forum area at PlumbersForums.net
I need the pipe as well Moonlight The ppart number for the Pilot Burner Assembly is; S203416 I will attach a pic thanksThe part number is for a pilot pipe rather than the pilot burner/assembly. Which are you looking for? Do you have a picture of the part you need? I inherited some boiler parts. Fans, gas valves and quite a few other boxes of bits and pieces. I haven't binned them as you never know. I did find a piece for a 37 year old boiler so you never know your luck. Not too many in there packages, so picture would be helpful to identify.
Hi gasmk1 that's what I was thinking, he is saying he needs exact part, plus the pipe (gas) I will go back to him and ask, but thanks for your input,Try this for the pilot burner.
That’s why other manufacturers make kits
I have looked through my stock today. I dont have a pilot assembly but a did have a aluminium tube kit 6mm OD. Have you thought about buying a tube kit and cutting and bending to the shape you need. The only thing that can arc on the pilot assembly would be the electrode. The injector can be cleaned. He could buy tube kit, new electrode and clean the injector. Hopefully sorted.Ok Moonlight ,I hope you can find something ,and as far as the old unit goes: the supply pipe is perforated so needs replacing and the pilot assembly is malfunctioning and arking
Don’t go to specsavers mate there expensive get one onlineHello,
I am looking on behalf of my installer for a pilot assembly for a spacesaver 60BR Mk11 GC 41-313-56 part no: 429788 any advice would be welcome
bests
Dave
Reply to Glow Worm spacesaver pilot assembly in the Gas Engineers Forum area at PlumbersForums.net
