Discuss Glow worm ultimate pcb in the Plumbing Jobs | The Job-board area at PlumbersForums.net
BPM
went out to a customer and found the pub burnt out. It’s an old ultimate 30ff. Found the replacement part number via glow worm archive and contacted Wolseley to get a price.
There does however seem to be a discrepancy. Glow worms part number is for a two fuse pcb, wolsely don’t list the compatible boilers as including the 30ff.
The single fuse pcb is listed as suitable for the 30ff. Now I’d normally always trust the manufacturer obviously but pcbs aren’t easy to take back obviously! To get a further opinion I went to another supplier who actually list both the part numbers for the single fuse and double fuse item as suitable alternatives!
Does anyone know a definitive answer as my local supplier only has one pcb left and I’m due round to fit it tomorrow and don’t have the opportunity to go back and take a further look!!
Attached are the pictures I took and it looks more like the single fuse unit to me?
Don't know if it helps but this is the part number according to the manual
Pretty sure that's a 2 fuse PCB from memory, I've got a 1 fuse and 2 fuse in the garage. I'll have a check in a min.
Chaps, open forum, OP are you Gas safe??? We will not give advice leading to illegal gas related repairs.
Send your Gas safe number and front and back of your card to me mate. We will get you the correct access.
Not disputing the fact, but PCB on an Ultimate doesn't require the removal of the combustion chamber door, nor touching any gas carrying related components.
After about 2 months :rolleyes::p His PCB change is tomorrow.
Think about it what does the PCB control. It’s the brain of the boiler. How is the OP going to test after installation that it’s working properly
Yes. GSR and fully aware of the rules..
And yet you’re still discussing a gas issue in open forum. Might need a re-read of those rules ;)
Reply to Glow worm ultimate pcb in the Plumbing Jobs | The Job-board area at PlumbersForums.net
