Discuss Glow-worm Ultracom 24hxi Heat Cycle Issue? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello Forum,
I've noticed at times that my boiler is heating in a very short cycle.
30 seconds on at full flame, heating to 65c.
30 seconds off, cooling to 37C.
It cycles like this for 10mins or so, then goes quiet for a period of time, then repeats.
- During this cycling the boiler is whistling a bit when it gets close to 65c and there is a bit of a clunk when the heating stops.
At other times it is heating with less intensity, for longer time periods (3-5 min), with the flame stength going up and down.
- It then stops heating for a long period.
Is this typical boiler behaviour or is something not right?
Doesn't sound normal depending on circumstance
Does it do this when the heatings cold
Hi Shaun,
Unfortunately, due to my health I rarely have the heating off.
In the past when the heating has been cold, I didn’t notice this short cycling.
- is short cycling the right terminology?.
I will try to find out during the week if we get a mild day.
It's expected if it only does it when the heating system is hot because the return temp is coming back warm
Reply to Glow-worm Ultracom 24hxi Heat Cycle Issue? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Went to a customer today their glow worm Ultracom 24 HE goes to fire up then cuts out turning the heating pump off, then does the same again...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
B
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
A
Good morning. We have a 10 year old Ultracom which now very frequently thinks there's a demand for hot water, even though there isn't, so the...
Andy Don
A
